Do you mean apk?
Why dont you just use the APK setup?
I also think that a 140 amp alternator is waaay over the top! a 90 amp golf 3/4 unit will be enough. I run a 90A in my 1.8t conversion and its been fine for 3 years now.
I'm not quite sure what you're trying do do?
Are you wanting to use the RV a/c compressor (which is a v-belt) by changing the pulley to fit the ribbed belt setup of the 2E?
If so, the main issue is even if you can remove the v-type pulley from the RV compressor and put on the ribbed 6PK1153 belt for a 2E setup, you'll have to make sure the offset will line up with the alternator etc. That RV pulley is very wide and has about 3 grooves in it...
The second thing is, the 2E compressor pulley has a clutch type pulley, and im not sure if they are removable/interchangable.
I would just find a 2E compressor and be done with it, or keep all the existing APK stuff on there. As long as the plumbing works...
Hope that helps!
Cheers,
Wade
