down shifting into first at high revs will give you a problem. sounds like your driving and not the car
at 3500rpm+ you shouldnt need to be dropping it to 1st!
when i was learning to drive i was told if the car is moving then you never use first gear.
it also sounds like you may have some sort of selector mis-alingment or worn bushes.
my old mk2 16v used to be funny selcting 1st, when pulling away i would have to drop it into second then first and it will go in every time. if i tried going straight for first it just wouldnt have it.
