aaaaand if you try to take a corner you'll be running on the rim![]()
Not quite the same, but you get the picture
But yeah, try and stick with the stock rolling diameter so your speedo doesn't change too much. Muck around with this tyre size calculator and find what size tyres you can use, and what manufacturer makes them. Keep in mind though that it's an American site so some tyres may not be available down under.
Rubbing depends on the offset of the wheels. MK2's can handle 205's unless slammed. Ride will be a bit bumpy on 35 profile but no way are you going to get sidewall roll like someone just described![]()
15x7 for the real euro look and rubber is cheap![]()
That's really the question.
The original 14" wheel/tyre configuration was just right for balance & nimbleness. Maybe many would disagree but I reckon increasing the rubber takes more away from the driving than it gives back. That might not be true on the track but it seems to be true for public roads where a greater variety of conditions operate.
There's a money consideration too. For the price of cheap Korean 17s you can get top brand 14s. If you want to put the steelies away I'd look out for some original Mk2 BBS alloys.
ive had 3 sets of different 17s on my mk2...
Lowered on Jammex springs...I would say 205/40s but there is variation between some brands too. Pov pack Nankangs etc are a little wider and rub (just) on hard corners. It also depends on what offset you want.....
Running silverstones now with no problems at all, even lowered it anothe inch or so still with no probs...My volk replicas have been good as far as clearance etc,,they are 17x7 tho.. but IMO 17s really do spoil a mk2
so ive gone 16x8.....
17s will make a mk2 look like an ATV unless you get the right offset.
here is mine on 17x7 with 205 /40
how it looked b4 it was dropped a bit more..........
and after more lowering
Cheers, Benny
www.axesent.com.au
Yeah sorry im on drugs.... 16x8 for shiz![]()
