Results 1 to 3 of 3
Thread: 16v kr starting issues
    Sep 2007
    perth western australia
    folks ... just want to get some info ?? i have a 16v kr in my mk1 golf , lately its getting hard to start ... when it starts, it chugs a little until i put a little bit of accelerator on then its fine , if i give some revs to 1200 rpm for a min or two , it will then idle at aroun 900 to 1000 , and its all good .
    Then some days after a drive when its warm it will take a while for the engine to start ? maybe ten seconds !!
    So maybe i asume it could be injectors or my fuel pump or even a filter ? not sure , while im driving and come to a stop sign ect.... its fine , doesnt stall , has good mid range acceleration , great but , just starting issues . shane
    May 2010
    NQ
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Perth. WA
    fuel pressure could be dropping of after the car is switched off, need to check the accumalator holding pressure.
    hard starting when hot could also be fuel vapourising in the lines ( heat soak) later kjet used a purging relay set up to bleed the fuel vapour from the cold start valve to "fix" the problem.
    Sounds like it could do with a fuel system pressure test Shane.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
