If you are doing some serious mods to your engine you may consider fitting aftermarket engine management along with larger injectors, though if you are sticking with the standard computer keep the standard injectors and just have them ultrasonically cleaned replacing the seals aswell. You can play with the fuel pressure regulator whilst monitoring it on a dyno and see if raising the pressure slightly yields any gains.
