Results 1 to 3 of 3
Thread: 1.8l 8v injectors - which ones and from where?
    Mar 2009
    My BBM fuel rail and adjustable FPR has arrived and its time for installation. Whilst im at it I am considering checking my injectors and possibly replacing/upgrading them.
    Any recommendations on which injectors will make a good and modest upgrade and where is the best place to source?
    Jun 2006
    Orange NSW
    If you are doing some serious mods to your engine you may consider fitting aftermarket engine management along with larger injectors, though if you are sticking with the standard computer keep the standard injectors and just have them ultrasonically cleaned replacing the seals aswell. You can play with the fuel pressure regulator whilst monitoring it on a dyno and see if raising the pressure slightly yields any gains.
    Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
    Mk1 twin eng twin turb
    scirocco gti 2.1l 16v turb 6spd
    Audi A4 B5 1.8t
    Mar 2009
    Thanks for the help.
    Nothing too crazy in the way of mods... at this point its a:
    Autotech 270 cam
    Autotech 4-2-1 exhaust header
    Nocat - hiflow cat
    Techtonics HD springs and hiflow exhaust valves retainers etc
    Lightweight hydrolic lifters
    Cold intake air filter
    BBM fuel rail
    Sard adjustable FPR
    and playing with a bmw 735i AMM at the momment...
    I have installed a wide band air/fuel ratio gauge so was going to see what info I can get from that. I will up the fuel pressure and see what comes of it.
