Results 1 to 10 of 15
Thread: 02A gearbox wanted for 1.8T conversion
    Sep 2011
    hello Mk2 Crazies
    I'm slowly getting my act togeather for the 1.8T conversion, but have discovered some issues swarting my plans.
    I was planing to use the 02R gearbox out of the polo GTI I picked up but it has nowhere to mount the rear bracket for the mount, Im not keen on dodgying up a bracket and I'd rather use stock drive shafts etc. So looka like I'm now after a suitable 02a gearbox.
    I will sometime down the track have some tuning done. and i'd prefer to use the cable shift & hydrolic clutch, i'd also like to use stock axles etc so looks like the 02A is the only way to go.
    open to sugestions on this.
    just to confirm, am i looking for the 02A off the vr6 and Diesel mk3's
    No bracket mounting points
    [ATTACH=CONFIG]19124[/ATTACH
    Attached Thumbnails Attached Thumbnails 02A gearbox wanted for 1.8T conversion-image-jpg
    1990 MK2 Golf GTI
    I'm confused. You've got 6 bolts there that can be used to hold a bracket so why do you need a different gearbox?
    Any machine shop or decent backyard mechanic could build a bracket to suit in an hour or two. You're not building a race car where weight is important so a strong bracket that's over engineered would be real easy to make.
    Paul
    May 2011
    Albury, NSW
    You should be able to find a VR6 one pretty easily - diesel golf however is pretty hard. I imported a CTN code gearbox from the UK - actually cost me next to nothing when the exchange rate was good. It was about $300 shipped. Probably be about $500 now. CTN is from a Passat b3/MK3 Golf and apparently has the best ratios for MK1 1.8T's.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Sep 2011
    Paul
    Hi Paul
    I did originally think I would use the bolts and make a bracket but I just assumed using those bolts may interfere with the integrity of the seal, my 020 ended up leaking from the gasket twice so last thing I wanted to do was to play with them and end up with a leak.
    Creating a bracket is not a issue, What the hell, I'll give it a blast and tackle issues it they arise
    Cheers Paul
    1990 MK2 Golf GTI
    Feb 2009
    Please Enter Location
    A VR6 gearbox in a 1.8t.LOL LOL LOL
    Nov 2007
    I have an 02A if you still want one
    I've got a diesel mk3 for sale. PM me if interested.
    This is the bracket you need to make.
    Camden, Sydney
    VR6 gearbox has a different bellhousing to the 02A used on a 4 Cylinder.
    You cannot bolt a VR6 box to a 4cylinder engine.
    You can pull the Vr6 box apart for the gears and put it in another 4 cylinder case. Or make a bracket.
    Sep 2011
    Quote Originally Posted by GTi Bhoy View Post
    Hi GTI boy
    Thanks I'll let you know when I get to checking the current box
    1990 MK2 Golf GTI
