Dumb question.
If i had 4k it still wouldnt be enough and ive already got wheels, exhaust, coilovers, sterio etc....
It depends what you want out of the car man. Coilovers would be in, bigger brakes would be out, stock is enough to handle the 80kw. Power wise, if its an RV then you will want alot more. If its a daily a decent sterio would be a go, depending on how much music you like. Rear sway bars are an expensive way to show people you can bash round abouts. The stock handling is very good, the coilovers should firm things up then it just comes down to how you drive.
I rekon:
Sterio (depends on what you want)
Coilovers ($800 hottuning - $2000 KW)
2L bottom end ($500 if you do it yourself)
Cam ($350)
Strut brace ($140 from Tim)
and then some dress up bits (ebay is your friend)
