Results 1 to 10 of 28
Thread: $4k to upgrade a gti
AusScare silver mk2 gti 01-04-2009, 07:00 PM
Spyda Dumb question. If i had 4k... 01-04-2009, 07:20 PM
AusScare Sorry about the dumb... 01-04-2009, 07:39 PM
Golf Loon aliasMk2 on here has an ABF... 01-04-2009, 07:55 PM
Jarred Since you cant mod the engine... 01-04-2009, 07:59 PM
AusScare Widetrack? I think it already... 01-04-2009, 08:10 PM
    Mar 2008
    silver mk2 gti
    Hey there,
    Just wondering what can be done with $4k to upgrade a mk2 gti as a daily and weekend windy rds car. Basically I'm buying a '91 gti off a VW mechanic from the gold coast and have some car cash left over.
    It's the one on the left here http://i256.photobucket.com/albums/h...uinn/2mk2s.jpg
    The first thing I can think of is coilovers, so that's a must, just not sure what types, hottuning? Only $800...
    Power wise is probably fine for now since I'm under the new P laws, so no fi or mods (tho this one does have extractors).
    So for $4k what are people's suggestions?
    I was thinking:
    • New headunit for ipod
    • Coilovers
    • Rear sway bar
    • Strut brace
    • Bigger brakes
    Current wheels are 17s, so I'll see how they look with the body lowered, but not a fan atm. And I won't be buying everything at once, it'll probly go in the order above and just because I have $4k to spend, doesn't mean suggesting $2k Brembo's if a $1k kit will be excellent as well. Exhaust upgrades worth it?
    All suggestions are welcome! Please try and post the price and where to buy if mentioning specific items.
    edit: 2/4/09
    Performance mods:
    • Exhaust
    • 2L bottom end
    • Cam
    Handling mods:
    • Coilovers
    • Strut brace
    • Brakes
    • Rear sway
    Feb 2007
    Dumb question.
    If i had 4k it still wouldnt be enough and ive already got wheels, exhaust, coilovers, sterio etc....
    It depends what you want out of the car man. Coilovers would be in, bigger brakes would be out, stock is enough to handle the 80kw. Power wise, if its an RV then you will want alot more. If its a daily a decent sterio would be a go, depending on how much music you like. Rear sway bars are an expensive way to show people you can bash round abouts. The stock handling is very good, the coilovers should firm things up then it just comes down to how you drive.
    I rekon:
    Sterio (depends on what you want)
    Coilovers ($800 hottuning - $2000 KW)
    2L bottom end ($500 if you do it yourself)
    Cam ($350)
    Strut brace ($140 from Tim)
    and then some dress up bits (ebay is your friend)
    MK1 GLS 3door
    A4 B7 2.0T
    Mar 2008
    Sorry about the dumb question, I'm just not sure what things cost in regards to upgrading a mk2.
    Looks like I'll just get the coilovers and hu for starters.
    I want the car for good handling, and getting around town. After a while I'll probably try a track day or two.
    edit: I've been told rear sways are quite good for the price ($200?)
    Camden, Sydney
    aliasMk2 on here has an ABF 16v engine and loom that would plug straight into your car
    And he is up near you.
    That would fix the Aussie Mk2 slow
    Jun 2007
    Eastern Suburbs Melbourne
    Since you cant mod the engine really, I'd stick to making it go and stop well.
    A widetrack using mk 3 gear in combo with a big break upgrade & disc rear end would be a top idea I reckon.
    If you want handling, I'd recommend a cupkit over hottunings. Since you've got a bit of dosh, look at getting some weitec coilovers or koni, there's a few options out there [I don't know them all]
    Wide track + big brakes + decent susp + swap bars = great handling from an already very good chassis.
    Sounds system, meh. Hey a radio and two speakers would be good enough for me.
    Keep a bit aside for repairs etc too
    i like volkswagens
    Mar 2008
    Widetrack? I think it already has rear discs, but yea was thinking some nice big brakes up front.
    Ok, I'll look them up.
    Does a widetrack involve cutting up the chassis? I probably don't want to go all hardcore just to get that little bit extra out.. My friend said rsb was good, and fsb doesn't improve it all that much?
    Yea I'll leave a bit there all the time.
    Where do I start for finding prices on suspension or brakes or sway bars and the like? Head down to supercheap or something? I read in another section someone saying they were upgrading their brakes, front drilled discs $130 and greenstuff pads $140 or so, is that the same sort of stuff I'd be after, is it all universal for brake rotors/pads? Is suspension universal as well, or does it have to say mk2 somewhere in the description..
    Jun 2007
    You'll have to get model specific parts, ie pads discs etc.
    Golfloon would be able to give you more info on a widetrack conversion, but you don't need to cut up the chassis.
    I'm pretty sure you just need the front subframe from a VR6 [or standard mk 3, Matt?], inc control arms and hubs I believe & the rear beam.
    While you do the widetrack, if you get VR6 stuff, you may as well use the VR6 brakes [280 or 288 mm discs] at the same time for more stopping power.
    AFAIK that's the cheapest/easiest way to get widetrack in a mk 2. You could use B3 passat stuff, but good luck finding a B3 passat!
    Start looking online for swap bars & uprated bushes and stuff. There are plenty of people here who've posted info before about these kinda things, so have a search and you're bound to come up with something. Start looking at buying from euro parts importers rather than supercheap. I'm sure there are some blokes in QLD who can point you in the right direction locally, but GAP is also good [o.s. though]
    HTH
    i like volkswagens
