Results 1 to 10 of 16
Thread: Zero tolrance speeding
    Dec 2009
    Oz
    Something I came across online.
    http://smh.drive.com.au/motor-news/m...324-1c8kp.html
    Formally known as mk6tsi
    Dec 2009
    Oz
    Tolerance.
    Stupid iPhone spell check.
    Jul 2005
    yep... there was a bit of it on today tonight or current affair show... caught a bit then switched off..
    lets face it... it was bound to happen.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Feb 2008
    Has anyone here taken a >5km/h over speeding fine to court, and used the ADR's as a Defence against these stupid tolerances?? I don't see how a state government rule can override a Federal government design mandate...
    Adelaide hills, SA
    Quote Originally Posted by blutopless2 View Post
    Yes, I saw one of these affair show. They used wrong drivers as an example. The drivers who lost the last demerit point and lost the license when they were driving way too much over the speed limit. They were arguing, if the greater tolerance was used they wouldn't lost their license.
    Anyone with the 1/2 brain would have to ask them; what did you do that you lost so many demerit points and why did you speed almost 20km over the speed limit?
    Dec 2009
    docklands , victoria
    right , i don't want to be a "whinging pom" but this makes my blood boil.
    "Australian design rules used to allow for a 10 per cent tolerance either way on car speedometers, but now the rules only allow for the tolerance above the actual travel speed."
    so let me get this right. I can now no longer use the speedometer in my car as a tool to indicate the speed i'm traveling at as it will be inaccurate due to all sorts of reasons outside of my control ,eg : the rolling radius of the tyre changing due to the heat difference from cold to hot when in use and the ambient temperature?
    The lawmakers need to sort out the tw4ts who won't let each other merge/exit safely on freeways , tailgate and drive around in 20 year old 5h1tboxes that have never seen a spanner rather than concentrating on ridiculously minor speed infractions.
    Mar 2010
    Witness Protection
    Media beat up.
    The new government that will be elected today has already made a statement that they won't allow this to happen.
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by monkeyalan View Post
    I think that the quote in the article was badly worded.
    Previously the ADR allowed for + / - 10 per cent tolerance. Now it allows for +10 per cent only.
    What this means is that, as is the case with all current VW's, the speedo tells you that you're doing 100km/h, but you're really only doing 93km/h (since they're about +7% out). Therefore, whether you've inflated your tyres too much, or just got brand new tyres, or even to account for the width of the needle, you're ok.
    Drivers of older cars though - they're potentially stuffed
    Dec 2009
    Quote Originally Posted by Corey_R View Post
    yeah , 107 on the speedo is bang on 100 using the sat nav and those freeway speedcheck things.
    So whereas before you'd have gotten away with an actual 102 / 3 kph (speedo reading or 109 / 110 ) , now it's 100 (actual speed) exactly or you're booked?
    I'm sure 1000's of life will be saved with this nonsense and it has nothing to do with revenue raising.
    Feb 2010
    Quote Originally Posted by hooba View Post
    Let's hope so because otherwise this is just too much.
    Folks that do -5 will now have another excuse to go -10 on the roads.
    2011 Mk6 GTI | CW | DSG | Bi-Xenon | GIAC | APR TBE | THS FMIC | Modshack
