Results 1 to 10 of 10
Thread: Why need rear proportioning valves??
    Oct 2010
    South Australia
    I've been told that when you upgrade your Mk1 to Mk3 rear disc brakes that you would need rear proportioning valves to adjust for the bias. Why is this?.
    I know a couple people who didn't use these and they have not complained about their switch yet.
    Jun 2007
    Eastern Suburbs Melbourne
    under hard braking the back can overtake the front! (due to increased stopping power at the rear)
    i like volkswagens
    Cheap, Fast, Reliable. Choose two.
    Sep 2009
    Chillaxing in Tas
    Quote Originally Posted by Stuwey View Post
    BWHAHAHAHA that is awesome!!
    <space for rent>
    Apr 2009
    But how hard do you need to brake?? normal street braking or racing ??
    -'75 Passat TS
    -'75 Passat TS (Project)
    No....its not a Piss-sat its a Pass-sat!!
    How hard do you intend on braking behind the next car?
    Old Minis are bad for this too, when you do a disc brake upgrade. Can make for some "interesting" stops at the lights!
    Boronia VIC
    You need them on the street especially in the wet or when braking downhill.
    Back will lock up and you'll go sideways into the intersection.
    Another option is to replumb the brakes and use a wilwood prop valve or grab the self adjusting unit on the back axle of a MK3 and intall that with the lever fixed in place.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    VW didn't go to the trouble of fitting them for the good of their health.
    They also compensate for changes in load, ie when you have 4 people on board, there's a change in bias to keep the car inline when you brake.
    Seized up ones were a nightmare in the UK.
    Nov 2005
    indeed you need them, i had the same thoughts untill i started the car and rolled up the newly layed driveway locking up 1 wheel easy as pie.... spend the time, pay the cash and you wont spin out and potentially crash your car your obviously building..... over 2 proportioning valves?
    dom
    Apr 2009
    You guys make a strong case. They sound hard to install, I'd rather stick with larger drums after reading this.
    -'75 Passat TS
