Results 1 to 10 of 10
Thread: Where to find bolt for tow strap??
    Feb 2007
    Brisvegas
    Hi, I'm wanting to add a tow strap to the front of the wee Polo but can't find a bolt to replace the factory steel screw in hook. Can anyone point me in the right direction?
    Pacific Paradise QLD
    Quote Originally Posted by VWindahouse View Post
    Why do you need it They dont break down that often. One should only use an approved towing device.
    Have seen results of incorrect towing methods causing a fatality
    Oh I see it might be the track car so use the ring and an approved D shackle to attach the strop THe shackle should be the same rating as the strop Not a 1/4in one from Bunnings
    Feb 2007
    Brisvegas
    Thanks mate but I think you're missing my point.
    WHich is???
    Feb 2007
    Brisvegas
    The front of the polo is very restrictive space wise, even more so with a massive front mount to fit in there
    so you don't get a heap of choice as to where you run your piping. In this case right in front of the factory tow hook receiver hole.
    So with all the track work I'll be doing I need a solution and that solution is a strap that can fit around the piping hence needing a bolt with the same thread as the factory tow hook.
    A good engineering shop should be able to give you what you want Take the factory ring in with you and they can match the thread
    Boronia VIC
    You'll have trouble finding an off the shelf bolt. From memory they're a left handed acme thread.
    I'd probably grab one of the generic aftermarket eyes and modify that.
    There's plenty on ebay, search for VW Tow Hook.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Feb 2007
    Brisvegas
    Thanks mate, yes left handed thread
    The hole is 15mm inside diameter and 75mm deep. You could get a bolt that goes all the way through and forget about the lefthand thread.
    Just needs to be able to do 85mm or so to get a nut on the back.
    Feb 2007
    Brisvegas
    Thanks Gav, just found out Troy did exactly that
