Dont know about VIC but in QLD you can buy L stickers at Supercrap etc also some Newsagents. Even saw some in a $2 shop
They are the VicRoads approved ones, or can I just print to size and blue tack them to my window?
Past - '95 VW Golf MK3 VR6
It's for learning manual so I need to display my regular P's and the instruction plates.
Where have you tried or just asked on here Some of these signs may be reflective and can only be made out of the correst material
Your local licencing authority would be a place to try
Ignore the photo, turns out it needs to be square. Tried searching online and can only find the truck ones.
I reckon I'll just print to size and laminate. Should be good enough.
Haven't seen them for sale anywhere. Can't imagine it's a hot item so probably why no-one stocks it.
Here you are 25 sec Google Driver Under Instruction Sign
Vehicle & Truck Identification Signs - Driver Under Instruction | Seton Australia Semms its Ok to make your own as per the rules here
driver under instruction plate means —
(a) if displayed on a car, a plate
approximately 150 millimetres by
150 millimetres bearing the words
"driver under instruction" in black
letters clearly marked on a yellow
background; and
(b) if displayed on a heavy vehicle or bus,
a plate approximately 525 millimetres
by 250 millimetres bearing the words
background;
I already found those that's why I'm asking and none of those are the ones I require as I need them for a car.
Convinced I will just print on yellow paper and then laminate together with a few sheets for thickness.
