Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: When is too much over-servicing never enough?
    I'm interested in getting feedback from forum members on the mystery (for me, at least) of tire rotation. My Golf has just come-back from its first service and without me asking, or any prior discussion, the dealer has undertaken a tire rotation and balance. The first service was due on the basis of time (i.e. 12 months since purchase) and the car had travelled just over 9,600 kms.
    I've checked the manual and it simply says that tire rotation should be done regularly (whatever that means). Is this normal and should I expect to have the tires rotated at every service? If this is indeed standard practice, how many rotations will the first set of tires on my car receive (on average)?
    Jan 2008
    They do it so they can charge you extra. It is not part of the standard service. Also if they are checking the brakes properly they should be taking the wheels off. Which means they are charging you $xx to roll the wheels front to back. Also unless you feel a shudder at speed you probably don't need balancing.
    Sent from my Nexus 4 using Tapatalk
    Jan 2008
    I normally do t myself as I have a decent trolley jack that I can get both front and rear off the ground at the same time.
    Oct 2013
    It depends on the wear your tyres are getting. Usually tyre rotation is done regularly but on condition. Its so easy to do that you might as well do it on each service when the car is on the hoistand most places dont charge for it as they have to take the wheels off anyway to check brakes and stuff! You can also do it yourself when you motice the wear on the front to be visually more then the rear. This is usually a good indication that its time to rotate.
    this message thrown at you from the window of my flying Golf!
    MY11 CW Golf RIntake, Tune, DP, DV+Superpro arms and ALKCustom 4" tipsTWM Short Shifter
    Jul 2012
    Sinagra, Western Australia
    Just be careful as all VW's tend to scallop rear tyres, which leads to a tonne of tyre noise when rotated to the front.
    Adelaide hills, SA
    Well, you can't please everyone. rotate the tyres - not good. Don't rotate the tyres - not good either.
    What did they charge you for the service anyway?
    Judging from the title of the thread, it must've been a lot.
    Who is messing with my profile?
    Tyre places like Bob Jane will recommend 5000km to10000km tyre rotations and do them for free for the life of the tyres if you bought a set of four from them.
    Jan 2011
    Brisbane - QLD
    I rotate / shuffle mine every a few thousand K or so. Also use torque wrench to tighten the bolts to spec.
    All my tyres are evenly worn
    My tiguan and gti have not exploded.. I must have been overservicing.
    Sent from my GT-I9300T using Tapatalk
    MINI Cooper S Clubman - FWD
    Jan 2011
    Brisbane - QLD
    But i remember vw underwood qld service offered me to rotate and balance my tiguan when they did 2nd yr service at 16,000k. They wanted to charge for it when they called and said that if not, the tyres would wear out quick (7mm left i measured back then)
    Oct 2013
    Eastern Melbourne
    LOL this is true.
    I on the other hand would not be impressed if they didn't rotate tyres.
    My mum has a subaru and the stealership rotates them every 2nd service. With the intervals at 10,000kms, it means that the tyres were unrotated for 20,000km. Not impressed.
    Quote Originally Posted by MightyCarMods
    I'd rather lose by a mile because I built my own car, than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book.
    -| "Laura" - 2001 Bora 4-motion (now sold) |-
