I thought I would start this one after a recent experience , what I am asking members is to tell us what they dislike or like about their VW . It can be design service or whatever .Okay I will start about what pee's me off , okay today a brake light goes out a no brainer but wait VW seem to be one of those companies that is hell bent on keeping their VW owners either poor or loyal . I had a blown brake light bulb as stated seems that in a Transporter and I am presuming other VW's as well they have designed the bulbs so you cannot buy an off the shelf one from elsewhere . The locating pins on VW bulbs are offset from side to side ie not opposite each other like everyone else's . Why do they do that ? before 2004 the pins were opposite and could be purchased anywhere almost , after 2004 no way . the bulb internally is the same as off the shelf so why offset the pins . Next one why do they fit those multi sided sort of torx bolts into a part that would most likely need to be replaced from time to time . In our vans they use those bolts to hold the rollers onto the side sliding door , last time I changed ours I had to resort to using an air chisel to crack the bolt , these were then replaced with high tensile "normal hex bolts "why can't Vw do the same ? . There are other things but will leave that for later . By the way I love our vans but sometimes the engineering seems stupid .
