Results 1 to 10 of 14
Thread: What battery should i get???
    Eastern suburbs of Melb
    Hey guys i need a new battery mine is kaaa---puttttt!!!!
    A replacment battery is $170 :O thats for a supercharge gold. (last one lasted less than 9 months )
    what should i get??? i want to run a good sound system and just want it to start every time no hassles!!
    Stu
    Apr 2008
    Surely that'd be within the warranty period?
    I'm a fan of the Optima range, but they're expensive. That said, an Optima Red Top would be good if your car will be sitting still for a long period of time...
    Otherwise, Century seem to have a good reputation.
    Nothing to see here...
    Yeh it is under warranty... BUT...i have a ruined rep with my old boss who it was purchased from and he will not replace it.
    What do you use??
    Suffolk UK
    Longest lasting one i had was a Varta, they also make OE Batterys for VW i believe...
    I can get a heavy duty century for 113 that good???
    Feb 2008
    Townsville QLD
    Quote Originally Posted by thestu View Post
    What do you use??
    The warranty for Supercharge Gold is 3 years. Your old boss may not want to replace it but any outlet that sells it will regardless of where it was purchased.
    The Supercharge Gold MF66 has a 670CCA with RRP of $219, the Century DIN65LMF only has 580 CCA and 2 year warranty but RRP is only $179.
    Granite Passat sedan TDI (125kw), DSG, beige leather
    Candy White Polo 6R, 66TDI, DSG, no options
    But I can't get a receipt...
    Sep 2008
    melbourne/woopwoop
    stu get an optima battery you cant go wrong man, pay the extra $$ for the real good shizzzzz
    85' MkII 1.8 K-jet(small Bumpers) SLAMMEDDD!! ( sold )
    91' MkII GTI sold!
    Erskineville, NSW
    you shouldn't need a receipt. When you fitted the battery, you should have marked the purchase record on the battery. That should be good enough for any bonafide dealer. If it's a 3 year warranty then it's probably 6 months FOC replacement then pro-rata after that. I'd recomend you contact Supercharge direct & ask them what your options are.
    Jun 2007
    Eastern Suburbs Melbourne
    as if the battery is actually dead? It's not that old, it should be OK, unless it's been damaged.
    Both my cars have crappy (brand) and old (ones dated '06) and they both work still.
    Even my battery in the diesel went flat (completely!) a couple times, but it was still good!
    i like volkswagens
