Results 1 to 4 of 4
Thread: Warranty Procedure and process help needed.
    Jun 2015
    I need to take my T Cross back to VW for a warranty issue. And was wondering if anyone had been through the process of doing so. Are you able to offer any helpful tips on making the process a bit smoother and with a little drama as possible.
    Do these things take weeks usually. Are they generally ok about it.
    Pacific Paradise QLD
    Depends on the dealer and whats wrong with car some are good some are **** Detail everything and maybe supply more info on here as getting a door lock fixed is a bit different to it jumping out of gear or something major If you get what I mean
    Dec 2006
    Kilsyth, VIC
    Pretty much this, depends on the problem, how common (and acknowledged it is) as well as how hard it is to fix.
    Even then, I've seen complex things done with zero issues and simple common things fought and lost.
    What's the issue?
    Jun 2015
    Thanks for the replys.I will take a few pictures and then post again with detail.
