Hi All,
A preview of the latest issue of VW Magazine Australia #25 can now be viewed at http://www.vwma.net.au
This issue goes on sale February 3rd. Subscribers should receive their copies over the next two weeks.
The SE Dubs Fest was given a good plug, and over the weekend the VWMA website will feature the show flyer as a pop-up from the left menu.
Also worth mentioning, is that fact I now own a 1980 Mk1 Diesel 5 door. The car is currently at my panel beaters having a few minor rust holes welded up, but other than that it's solid and a runner. Each issue of the magazine starting #26 will feature an article on its progress, beginning with the suspension and brakes (which there seems to be very little of...?)
Craig
is that yellow mk1 on the cover even in oz???????
White 95 vr6, colour coad, koni, neuspeed, 16 x 9, samco!
cool craig.
looking forward to some installations with the mk 1. and of course, congrats on the mk 1![]()
yeah... this'll be a pretty cool issue, has the article i wrote on the whole DOVW weekend with all the boys n girls and what we did......
also huuuge coverage on the whole DOVW vic
cheers craig again for the SEDF coverage mate! hope you can make time to come see what SEDF is about mate! start driving down mate!!
also hanging to see what progress in done on the MK1 you just purchased! should be gd!!!
cheers
dom
Every effort, Dom, to get to the show, but time is against me.
Could someone put me in the direction of a thread improving Mk1 brakes? I do recall reading it, but can't remember where.
http://www.vwwatercooled.org.au/newf...=holiday+brake
and
http://www.vwwatercooled.org.au/newf...ad.php?t=11689
all thanks to Pete Jones
Thank you.
SE Dubs Fest flyer is now on the VWMA website, left menu bar as a pop-up/
will be good to see some mk1 action being featured in the magazine i love air cooled stuff but my passion is early water pumpers
As for brakes not sure on budget easiest conversion is mk1 cabby, mk1 gti and some early audi calipers and use mk1 gti rotors, bolt on no mods required use standard master and brake lines, i think you need new flex brake line depending on which calipar you get my memory is bad but the 1980 rubber brake lines properly looking 2nd hand anyways so a new set of braided lines wouldn't go astray, easy as that its what i used to run on my car (stocko 13" rims wont fit),
Ive done this conversion 3 times now, 110% improvement over stock best option is ebay usa or uk to source cailpars or if your in no rush search the forums and see what pops up.
You can buy the rotors hear in Aus new i have done in the past if you want cross drilled and slotted overseas is only option, you can go the way i have and use 280mm floating rotors but its only a diesel![]()
