As usual you're ractionis pure frantic fantasy. That is not what he described. He's described it the engine as running 200rpm higher at the same speed in the same gear which is impossible without a change in the gearing. It's purely a mechanical equation - engine revs x gear ratio x final drive ratio x tyre diameter = road speed. Like many things wth you simple maths isn't a strong point with you - I suggest you go back to what youseem to be good at...being a shill for the ambulance chasers.
Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
