Yeah all they could really do with a "stealth emission tune" is drop fuelling ( and thus overall emissions, who cares about power ), which in turn lowers EGT's and thus NOx. The economy figures would also look great. Wai is right in that a bit more boost would lean things out ( which is fine for a diesel ) and probably assist passing a test. Add to that a 100% duty EGR further dropping NOx. Particulates will go through the roof, but who cares if the DPF loads much faster in testing, none of that comes out the pipe into the test rig.
My guess is the software fix will be the same economy, a bit less power overall through the rev range, and more EGR. I bet it will still meet 103kw and 320nm at some peak, on some dyno, somewhere, we all know the massive variance there.
Catchcan time people.
The smaller sub 2.0 TDI engines always struggle with their physically smaller cats and DPF's, added to the fact these small cars are often city driven rather than chosen for highway vehicles, and reduce the chance of proper heat and passive cat/DPF regens.
Probably be a very good thing is the little-un's had a proper fix, I hear of a LOT of DPF drama with the small TDI's.
