Interesting. I wonder if they were disabling the EGR, like so many owners do?
I own a Japanese diesel 4wd. The engine is notorious (like many others, I guess) for clogging the intake with a thick black gunge - a result of soot from the recirculated exhaust gas combining with oil fumes from the PCV system. It's common for owners to disable the EGR in one of a number of different ways - this both stops the soot, and improves fuel economy, at the expense of NOx emissions. Of course, a catch can will also improve the oil part of the gunge problem, but not the fuel economy problems. Surely manufacturers could add a catch can to their engines as a standard inclusion for a lot less than we can add them as aftermarket accessories.
Lately, I've been monitoring the "commanded EGR" value with an OBDII tool, and noticed something interesting. Cruising on a flat road at 100km/h in 5th (auto) the EGR is continually varying, but I guess averaging around 20%. After dropping back to 4th (manual mode) for a town, I forgot to change back to 5th when I resumed cruise. I worked this out when I noticed the EGR was staying closed. Select 5th, it opened, select 4th, it closed. Can anybody explain why it would do that?
