Page 95 of 157 FirstFirst ... 45859394959697105145 ... LastLast
Results 941 to 950 of 1569
Thread: Volkswagen under investigation over illegal software that masks pollution
  1. #941
    Pacific Paradise QLD
    Quote Originally Posted by ian View Post
    Just received an update on the Diesel software cheat and VW are now claiming they have a solution ,that will not effect engine output or fuel economy whats your thoughts
    Wait and see if it works. What else can you do
  2. #942
    Jan 2008
    Sunshine Coast
    Postulate and freak out?
  3. #943
    Quote Originally Posted by Greg Roles View Post
    Hardly worth getting in a lather about when we dont really know anything is it?
  4. #944
    Sep 2011
    It gives me something to do when I'm not causing respiratory problems in children.
    Former owner of MY12 GTD with DSG
  5. #945
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by ParaBul View Post
    Considering most 3.0 litre tradie utes like the D-Max have only recently gotten DPF's and proper NOX cats, not sure why you feel bad. For sure VW is putting out higher than expected, but how high compared to the typical Australian diesel?
  6. #946
    Dec 2012
    Perth, Western Australia
    Heh... I was behind an old Hilux Surf early this morning as I got on the freeway. The Surf was rolling coal from around 45kph on the on ramp for a good 2-300m to get up to 100kmh. DAYUMMMMMMn.
    1981 Honda Civic hatch. Proper AUTO REVERSE cassette player. AM/FM with Stereo speakers. Four (yep, FOUR!) speed manual. Full cloth trim seats. HALOGEN lightbulbs! Factory options fitted: rear wipers and washer, "Go Fast" wheel covers & electric front windows.
  7. #947
    Jan 2008
    Sunshine Coast
    Quote Originally Posted by Eaglen00b View Post
    Oddly enough, as much as we all hate seeing and breathing that obvious black soot, the fact is you just cough that back up. It's the nano soot from DPF's that is starting to show up in peoples bloodstreams, seems it is directly absorbed via the lungs. Only with further added catalyst do you burn that down to virtually zero, luckily on smaller diesels the levels are low. There is no free lunch with regard to emissions.
    Different story with NOx, the whole crux of this debate, but oddly enough that's far easier to handle, at least in my sports DPF testing. I do however have a much bigger initial NOx cat than the MK6 era diesels, only in the MK7 do VAG get serious with the NOx cat size. It does seem odd to me they had so much trouble with what is from an initial glance, a very very well designed system. Then again I'm not trying to meet the very latest Euro levels set in the USA, and each level is an order of magnitude harder to meet.
  8. #948
    Feb 2014
    Central Vic
    I'd be saying to them - show me the before and after torque and power curves, before you have anything done to it.
  9. #949
    May 2010
    Bundanoon NSW
    Just found this link on an older Passat posting.
    This explains in detail how exhaust filter works.
    http://www.volkspage.net/technik/ssp/ssp/SSP_336.pdf
    OK This is for older TDI systems, with common rail just coming in.
    It does however explain how complex this whole system is, and why no simple solution.
    MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
  10. #950
    Feb 2010
    N.E.Victoria
    Quote Originally Posted by twincab View Post
    Received an e-mail from Skoda Aus. stating that our '14 125kw Superb 4x4 is fitted with the EA189 engine and has the offending software. No surprise, will have to wait till the smoke clears.
    Well the class action deadline has passed and we didn't sign up. Went on the MB web site to sign up, filled in all the imformation, got to the page with the aggreement/contract After wading though it and not understanding most of it got cold feet and backed out. I know it's not supposed to cost anything but we don't have a legal background and all the bits about uplift fees and everything else was doing our head in.
    Have we done ourselves out of compensation, probably.
