Page 19 of 157 FirstFirst ... 917181920212969119 ... LastLast
Results 181 to 190 of 1569
Thread: Volkswagen under investigation over illegal software that masks pollution
  1. #181
    Apr 2011
    Supposing you're assumption is correct.. How will you prove it? Dyno before and after?
    Simpler to avoid the recall surely if you're concerned.
    Sent from my Nexus 5 using Tapatalk
    If we avoid the recall, then aren't we putting ourselves at risk of being fined? Yes, my friends have suggested doing a dyno before and after. On the same day even.
  2. #182
    Jun 2011
    Sydney NSW
    There are very distinct rules that vehicles have to meet.
    First, the ADRs have an overriding statement in them that say that the vehicle must be manufactured to comply with the rule. No individual can be issued with a defect notice (for example) because the vehicle fails to meet the requirements of the ADR. Also, as far as I can tell, the cars involved WERE manufactured to comply, and they did comply.
    Next, in NSW (for example), the requirements of the ADRs apply to "vehicle that have not been registered". Until a vehicle has been registered, the EPA (or whatever they are called this week) can take any vehicle that has not been registered off the showroom floor and put it through the test specified in the ADR.
    For vehicle that HAVE been registered, there is a requirement to meet a maximum CO level (not CO2) at an engine speed specified in the rule. This is measured by way of a probe put in the exhaust pipe and and the engine run at the specified speed. This applies to both petrol and diesel fuelled vehicles. Additionally, diesel vehicles must not emit visible smoke for more than a specified time.
    So, no one can be required to have anything retrofitted, because the vehicle has already been registered. The government would have to introduce special laws to make this retrospective, and this would open a can of worms as it could be extended to a whole lot of other things. This is much the same as safety recalls. The government can mandate a recall on the manufacturer/distributor, but individuals can not have someone knocking on the door demanding anything be done.
  3. #183
    Dec 2012
    Perth, Western Australia
    Not a bad idea actually. It will most definitely help if you have documentation to support your claim of degraded vehicle performance if things go that way.
    1981 Honda Civic hatch. Proper AUTO REVERSE cassette player. AM/FM with Stereo speakers. Four (yep, FOUR!) speed manual. Full cloth trim seats. HALOGEN lightbulbs! Factory options fitted: rear wipers and washer, "Go Fast" wheel covers & electric front windows.
  4. #184
    Gosford Central Coast NSW
    Quote Originally Posted by wai View Post
    Assuming they even tried a CO and particulate test on any of the VAG TDI engines affected, they would pass easily with or without a software change.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  5. #185
    Adelaide hills, SA
    Quote Originally Posted by Eaglen00b View Post
    Since the power and the torque that manufacturers specify and advertise is from the engine dyno not the chassis dyno, you most likely don't have a claim.
  6. #186
    Dec 2012
    I should clarify. The intent of getting the before and after dyno test done is to confirm whether the VW "fix" has any effect on performance. I'm not talking about slick glossy brochure quoted power and torque numbers as they are (and should be taken as)indicative. There is absolutely no flocking way that every identical model and spec of a vehicle rolling off the factory floor will have identical power and torque outputs. Engineering tolerances introduces some variability.
    The "before" dyno is the baseline. Nothing to do with engine or chassis dyno. It is the relative difference with the "after" dyno test which is of interest.
    To ensure integrity of the dyno results, ideally a copy of a calibration certificate should be obtained for the test equipment so the standard range of error is known. So one gets results like 132.7kW +/- 0.5kW and 378nm +/- 1nm (for example).
    However, if the "fix" gets equal or better results, then of course there wouldn't be a claim....
  7. #187
    Jun 2009
    Even a dyno isn't going to give you valid evidence as you would need near identical conditions to be able to validate the power loss.
  8. #188
    Erskineville, NSW
    Quote Originally Posted by Eaglehawk View Post
    fined for what & when? I've never had a car subject to emissions testing in my life.
  9. #189
    Apr 2011
    wai's post was very informative, consider my question moot
  10. #190
    Dec 2012
    Smile
    Quote Originally Posted by team_v View Post
    Hmmm... I disagree. Granted, we'll have to wait and see what transpires overseas and locally in terms of documented effects of the "fix". But if dyno testing does pick up a gross difference in results one could say that on the balance of probabilities, taking into account the massive scandal VW finds themselves in, the "fix" had something to do with it.
    As for individual claims, I believe dyno testing documentation will help to assert any claim when viewed in conjunction with the body of evidence in the public domain.
    Regardless, I'd would still much rather spend the relatively small sum to get the testing done then NOT needing to use the results instead of saving that miniscule fee by not doing the testing and kicking myself later.
