Don't know that clarity will come on Monday. All I think we can expect is a list of which models of car have EA189 engines with the same ECU code and that further testing will need to be done to determine the impact of the code on emissions in combination with local fuel quality.
Assume global engines have the same ECU code. Emissions regulations are different. Assume that the ECU has code which works hard to minimise NOX emissions under the testing load scenarios. At other times, the engine has to manage CO2, particulates and performance. As we have seen in the ICCT Sept 2105 white paper, almost all small diesels on the market have problems blowing more NOX in real world tests. Not sure this is "cheating" more than any organisation puts its best foot forward for accreditation or certification and does things differently in the "real world".
If the engines to euro5 standard manage to pass our euro4 based legislation, there is not an issue with compliance. There is a media driven perception problem if the code is more specifically to "turn off" emissions control when not in test, but I think this is really rather an unlikely scenario. More likely that emissions are optimised in test scenarios and less optimal in real world and all small diesels are guilty. (Does the BMWX5 do better because it is bigger??) The corporate embarrassment problem is that emissions were 35x higher in "real world", but that test might have been biased to hills.
Maybe the problem started when the pre-EA189 engines with LNT changed to oxidising catalyst+DPF unit and then the code gets tweaked to maintain emissions performance without having to re-engineer????
2015 Polo Comfortline 6M + Driving Comfort Package
2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
(2008 MY09 Polo 9N3 TDI retired hurt hail damage)
