Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 121 to 130 of 134
Thread: Volkswagen Issues Global Recall of 2.64 Million Vehicles
  1. #121
    Trinidad and Tobago
    I really do find it strange that many 2012 models don't seem to be mentioned anywhere.
    Audi states october 2012 to April 2013 here:
    Audi A1, A3 and TT 2012-2013 7-speed S tronic models > Audi Australia
    while Audi states July 2008 and July 2011 here:
    Audi A1 and A3 information 2008–2011 models > Audi Australia
    I'm also still confused as to whether the oil in the mechatronics is to be changed or is it the oil bathing the clutches themselves to be changed?
  2. #122
    Aug 2013
    Neither... The DQ200 is dry clutch so there's no oil around the clutches and the mechatronics unit itself is filled with hydraulic fluid and sealed. As I understand it they're replacing the oil that the gears are in.
    MY13.5 Polo GTI - Flash red
  3. #123
    Pacific Paradise QLD
    The oil that is being replaced is in the MECHATRONICS module.
    The gears have separate oil and are in a different part of the transmission to the mechatronics.
    It is fully replaced as you cant dip it to see if any is missing It is a complete drain and fill with a designated amount.
    I know because I asked for the filter in the tranny to be replaced when they did the recall and was told that the filter and the oil it filters was in a different part of the box and would not be touched during the recall.
    The recall invoice has the details of the replaced unit and the oil as well Has been documented earlier in this thread
  4. #124
    Trinidad and Tobago
    Quote Originally Posted by AndrewBurns View Post
    The clutches are bathed in 1.7 litres of oil. It's a "dry" clutch in that the amount of oil is low compared to traditional gearboxes. Automatics for example can have 5+ litres of oil. Similarly for manuals.
    As Hillbily stated this oil is separate from that used for the mechatronic unit which has 1 litre of hydraulic fluid according to VW documents.
  5. #125
    Apr 2010
    I spoke to my dealer who said that the oil was replaced with the mineral type along with the mechatronics as part of the previous DQ200 recall that I had actioned a couple of months ago.
  6. #126
    To confirm this I asked VW AU
    Relevant part of reply QUOTE" As the vehicle had the voluntary recall service campaign 35C1 completed prior the vehicle will not be affected by the new announcement as the oil in the gearbox has already been replaced."
    This was the oil in the MECHATRONIC unit that was replaced
    The full details of the recall are here and includes multi years NOT JUST 2012
    http://volkswagenaustralia.com.au/internationalrecalls/
    I again queried if the Mechatronic oil and the "GEARBOX" oil is different as was told by my dealer.
    Awaiting a reply
  7. #127
    Ok so I asked VW Australia about it and this is the answer I got My next question is why didn't the dealer change the filter as I asked
    Quote!!!!!!!
    Further to this our technical team have advised that the mechatronics oil is not changed but the complete mechatronics unit is replaced. The oil that is changed is the gearbox oil/gear oil.
    The voluntary recall service campaign 35C1 includes replacing the mechatronics unit and gear oil.
    The mechatronics hydraulic oil is inside the component and is completely sealed for life/non serviceable and cannot be drained nor filled.
  8. #128
    Trinidad and Tobago
    Maybe because there is no filter to change on the dq200?
  9. #129
    Quote Originally Posted by Rawcpoppa View Post
    Maybe not but I read on here about changing it so it must be correct LOL
    Also the dealer said we don't change that. So either there is one and they didn't change it, there isn't one and he didn't know or the info on here was wrong ( heaven forbid) ROFL
  10. #130
    Trinidad and Tobago
    The oil filter is changed at 60,000 km on the dq 250 6 speed dsg.
    No filter for the dq200.
