Results 1 to 5 of 5
Thread: Using a dj smoke machine to find a vacuum leak
    Car is MK4 golf 2002 1.6L engine code AVU
    I know I can use a propane torch for this and others use carb cleaner but don’t really want the engine running and flammable items around so would using a dj smoke machine adapted with some tubing do any damage to the car in trying to find a vacuum leak. My concern is MAF sensor damage as I think the rest should be ok.
    If its ok to use where would be the best place to connect it to the vacuum system so it gets into all parts.
    Thanks
    Zeroasylum
    Sep 2015
    Western Sydney
    You could always pull the sensor and tape up the hole?
    Sent from my D6653 using Tapatalk
    It might make the car want to take drugs and dance all night long , but i don't think you will have any issues with causing damage etc. Give it a try.
    Jul 2012
    Sinagra, Western Australia
    Smoke machine will help but you will also wanna pressure test it as well, it is abit hard to see leaks unless there is pressure as the smoke will just sit in the system.
    Sent from my HTC_PN071 using Tapatalk
    Volks Handy
    Servicing - Repairs - Diagnostics - Mobile fault scanning/clearing - A/c work
    10 years experience working for Audi/VW/Skoda
    Now in Perth NOR, Western Australia.
    Dec 2014
    coopers plains, QLD
    Lentil can, bike valve, about a pump per psi. That's how I tested mine
    Attached Thumbnails Attached Thumbnails Using a dj smoke machine to find a vacuum leak-wp_20150602_19_21_37_pro-jpg
