Originally Posted by
Lucas_R
If you get a Q5 then i would definitely stay away from the 2.0 Turbo petrol engine (which is the most common engine) as this engine has quite a few issues (timing chain stretch, timing chain tensioner failing causing total engine failure, piston ring issues requiring new pistons and rings to be fitted....just to name a few).
The 3.2L V6 petrol, or the 2.0TDI / 3.0TDI (both diesels) in the Q5 would be the much safer pick.
The Touareg is available in a V6 petrol engine. This engine is generally very reliable (same engine is used in various Audi's and other VW's) but bear in mind it will be very thirsty pulling the weight of the Touareg around. I very much doubt you will get anywhere near the claimed 10.1L/100km figure.
Another bonus of the V6 petrol engine is that its a nice smooth and great sounding engine, as well as being quite easy to work on for maintenance items (spark plugs/belts/etc).
