Results 1 to 10 of 19
Thread: Trouble with links not working
    May 2010
    Bundanoon NSW
    Greetings to all the experts
    Lots of interesting links on this forum. But they do not work for me.
    Only way to use them is to right click, look at properties, copy, then paste into a new tab.
    Using MS explorer 8, compatibility mode turned on, latest copy of Symantic anti virus, and running Windows 7
    Have torn my hair out checking possibilities.
    (Have found a similer problem on a couple of other sites, but otherwise all other links I come accros work OK
    Yes, I know, not really a Watercooled item, but so darned frustrated
    MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
    Apr 2010
    Sydney,NSW
    Most links in threads open in a new window so it is likely that the popup blocker is stopping this. You can add this site address to the popup blocker exclusion list, see if that makes a difference.
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
    Dec 2006
    Kilsyth, VIC
    Can you post a link to a couple of threads where a link doesn't open for you, that way we can have a check and see what's going on.
    May 2010
    Bundanoon NSW
    Quote Originally Posted by The_Hawk View Post
    Popup blocker kept turned off. (Found this trap a while ago)
    Not able to directly copy URL, had to go into properties then copy and now paste here! (Same problem)
    Upgrade Golf Headlights to Osram Nightbreaker | my-gti.com
    Will now see if this works
    Naah, same as before!
    By the way, earlier (shortly after joining) was able to click onto [More] under the standard emotives beside this reply and see a lot more! Now does not work.
    Edit post. added another link.
    Golf 6 red/clear LED taillights
    Apr 2010
    Sydney,NSW
    If you right click on a link do you have 3 options at the top of the popup menu; Open, Open in new tab, Open in new window?
    Do the second two work?
    Adam
    Previously -
    2002 Bora V5
    May 2010
    Bundanoon NSW
    Have just found that if I "Copy shortcut' then paste into blank tab, this works also. Not perfect, but a lot better
    Does not work for [more] relating to emotives (smilies). this is javascript.
    Apr 2010
    Sydney,NSW
    Is this your own personal computer or a work one? If work then I suspect they have applied a group policy to lock down IE.
    Adam
    Previously -
    2002 Bora V5
    May 2010
    Bundanoon NSW
    Quote Originally Posted by Rybky View Post
    Adam
    "Open" and "Open in new window" (during right click button pressed only) shows URL at bottom of screen, but no further action.
    "Open in new tab" brings up the new tab, but no action. No change to address shown top of screen address bar. No sign of rotating ''busy" icon.
    Pc is private. Acting as if there is a general block for any action outside of current web page.
    Dec 2006
    Kilsyth, VIC
    All those links are working perfectly for me in Firefox and Safari. I'll boot up one of the windows machine and give it a bash over there too, but for the moment it looks like it might be an issue with your computer
    Dec 2007
    Brisbane, Southside...
    I just tried IE8 normal and IE8-64Bit with all latest updates, latest Chrome, also latest Firefox and latest Safari on a fully up to date Window 7 Premium 64-Bit with no dramas at all in any of the browsers. I'm also running McAfee Security Suite.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
