Results 1 to 10 of 11
Thread: Thread adapters?
    Sep 2006
    West Sydney
    Thread adapters?
    Hi guys, I'm in need of a thread adapter:
    Wondering where I can find them/have them made locally? Looking for one that has a female M12x1.5 and male 3/8"-16 (UNC). Any help is appreciated!
    Cheers.
    Point Cook, Vic
    have you tried the usual places like pirtek etc?
    FOLLOW US ON FACEBOOK
    Boronia VIC
    What's the application?
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Jan 2008
    Newcastle, NSW
    Ryco hydraulics could possibly have them? Any fastners shop should have them too Ray?
    Feb 2008
    mOOROOLBARK
    that sort of fitting isnt standard it would have to be custom made in a lathe, maybe e fellow dubber in sydney would be able to make one at home or work
    or just go to your local machinist
    Jun 2006
    Orange NSW
    What's it for, Ray? I can probably knock one up for you...
    I agree with Pete J.
    What is the application its to be used for?
    You may be making a mountain out of a mole hill & there just might something alot simpler to use.
    I did a search through all my fitting catalogs which have a s$^tload of adapters to suit nearly every application, but there is nothing to be found that is like that.
    I haven't even come across a time-sert adapter. Its either metric or imperial
    Sep 2006
    West Sydney
    Just want to use something out of the ordinary as a shifter knob. Thread size on the shifter shaft is M12x1.5 whereas the "shifter knob" is 3/8"-16. I don't know if I wanna go ahead with it, but if I do, it would be good to know where to go to - I haven't checked any places yet, but have scoured some online hardware sites and like you guys have pointed out, it's a very unusual application.
    Quote Originally Posted by rayray086 View Post
    Ah ok.
    It may be possible just to drill the shifter knob to remove some of the Imperial thread eg. 10mm drill bit & re-tap it with a M12x1.5 tap
    Jun 2006
    Orange NSW
    Quote Originally Posted by golfworx View Post
    Ah ok.
    Yep. Definitely the way to go.
    FYI, for metric threads, just minus the thread pitch off the diameter and it will give you about the right size tapping drill. Eg: For M12x1.5, you would use a 10.5mm drill.
    This will give you roughly 75% thread engagement which is plenty.
