have you tried the usual places like pirtek etc?
Hi guys, I'm in need of a thread adapter:
Wondering where I can find them/have them made locally? Looking for one that has a female M12x1.5 and male 3/8"-16 (UNC). Any help is appreciated!
Cheers.
What's the application?
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Ryco hydraulics could possibly have them? Any fastners shop should have them too Ray?
that sort of fitting isnt standard it would have to be custom made in a lathe, maybe e fellow dubber in sydney would be able to make one at home or work
or just go to your local machinist
What's it for, Ray? I can probably knock one up for you...
I agree with Pete J.
What is the application its to be used for?
You may be making a mountain out of a mole hill & there just might something alot simpler to use.
I did a search through all my fitting catalogs which have a s$^tload of adapters to suit nearly every application, but there is nothing to be found that is like that.
I haven't even come across a time-sert adapter. Its either metric or imperial
Just want to use something out of the ordinary as a shifter knob. Thread size on the shifter shaft is M12x1.5 whereas the "shifter knob" is 3/8"-16. I don't know if I wanna go ahead with it, but if I do, it would be good to know where to go to - I haven't checked any places yet, but have scoured some online hardware sites and like you guys have pointed out, it's a very unusual application.
Yep. Definitely the way to go.
FYI, for metric threads, just minus the thread pitch off the diameter and it will give you about the right size tapping drill. Eg: For M12x1.5, you would use a 10.5mm drill.
This will give you roughly 75% thread engagement which is plenty.
