Results 1 to 7 of 7
Thread: steering wheel turning left when braking by itself
    Feb 2010
    BRISBANE
    so got my new car, secondhand.
    and the only problem at the moment is when I'm braking at to the lights. at the end the steering wheel turns to the left...mmm. why? god why?
    diagnose this problem for me.
    1. airlock in brakes?
    2. seized caliper?
    3. wheel alignment?
    Quote Originally Posted by hoontime View Post
    2. seized caliper?
    3. wheel alignment?
    And what car is it?
    Sounds like your left caliper is sticking a fraction of a second as you back off the brake pedal compared to the right caliper.
    Might be simply fixed by removing the brake pads and giving the caliper a clean with a brush.
    Paul
    Paul
    Depending on what car it is, I am thinking it has a worn out rear LCA bush on that side. allowing the wheel to move back in the arch as it stops.
    Feb 2010
    BRISBANE
    it's a 11/1999 Nissan Pulsar SSS. 4 disc brakes. ventailed and solid.
    I'll withdraw my comment then. What about joining a Nissan forum and asking there?
    Dec 2009
    Kew, VIC
    Could also be a stuck float pin causing the pad to bind on one side of the disc — I had that happen to a 3 litre Cressida. Symptom was the same.
