Results 1 to 2 of 2
Thread: the spare wheel
    Jul 2010
    Robina Gold Coast
    the spare wheel
    I posted this in the Tiguan section ,and was hoping for some advise ,no replies so i'm posting here
    The Spare wheel
    i know this has come up before but ,ive been offered a full size spare that could fit my Tiguan off a Passat
    its a 235/45/17 but as my car is a 235/55/17 i know the circumferance might be slightly smaller but could it cause any damage ? i could remove the tyre and fit the right one but as its only a spare and might never be used .would it be ok ?
    Apr 2017
    belgrave victoria
    Quote Originally Posted by ian View Post
    The Spare wheel
    Hey mate
    If your looking for a full size spare you are after a wheel/tyre combo you can stick on and not worry about till you get other one fixed correct?
    If so (thats why most go full size spare) it is imperative you match rim/tyre size to your fitted rims/tyres as a rolling diameter difference will cause axle wind up and can damage your drivetrain
    Thats why the emergency spare is not rated at more than 80kph and no more than 50klm driven on it to avoid damage
    If your not going to get them matched just stick with the emergency spare because you will have the same limitations with your mismatched set
    If its important to you to have a full size tyre spare (i was a bit obsessed about a full size spare when i got my new golf but with research i got over it i still get a nervous tick from time to time ) Change the tyre you don't need a superduper one but you do need one that matches otherwise don't bother
    Happy driving
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
