Nah, it's about 15mm lower on the right than on the left.
Dunno, I might raise it a bit... probably not hahaha.
If it's not rubbing...![]()
if you drive in the car by yourself, having more weight on the right hand side will cause the RHS to 'wear' or sag a bit quicker than the left.
also check something else isn't busted, maybe check strut tops, see if they're busted? & make sure the coils are 'set' at the same height (same amount of thread left)
As said already coilovers in general will bed in over time.
I had no problems with my hot tuttunings in the GTI they were awesome![]()
