1981 Honda Civic hatch. Proper AUTO REVERSE cassette player. AM/FM with Stereo speakers. Four (yep, FOUR!) speed manual. Full cloth trim seats. HALOGEN lightbulbs! Factory options fitted: rear wipers and washer, "Go Fast" wheel covers & electric front windows.
I assume he drove it to NT and used the no speed limit area![]()
1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
1996 Vento GL (white) - RIP
I could say I have done 160km/h but noone would believe me because all my cars are slow diesels.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Interestingly an ELM327 device plugged into the OBDII port through DashCommand gives the same speed readout as my GPS. The dash (both needle and digital display), however, is about 5% optimistic. So the ECU knows how fast you are really going.
The VE Commodores I've owned were always 2 kilometres an hour faster, irrespective of how fast you were going.
My polo seems to stick exactly 5km/h over from 0-130km/h
I had a VR commonwhore a couple years back, that was bang on the money.
I SellNissansSkodas.
IT'S HEREEEEE 18' Skoda Octavia 110tsi Manual Hatch | Race Blue | Tech Pack | Luxury Pack | Panoramic Roof | Turini Alloys | Various VCDS Tweaks | RS Spoiler | Mars Bar Holder
R.I.P; 13' VW Polo 77tsi Comfortline Manual | Candy White | Sport Pack | Pioneer AVH X3800DAB + Clarion Bass Pack
Isn't one of the main reasons for this so that if you go for a larger wheel/tyre combo, the increased rolling diameter doesn't result in your speedo under-reporting (ie showing less than actual)? Otherwise you would need to get it recalibrated every time you change wheel sizes, which would be a hassle given the options you can get from factory.
The good part is - if you fit larger wheels any time down the track it is still ok!
I just use my GPS speed to confirm actual speed vs indicated on the speedo and all is good.
Have been doing this for the past 15 years - not sure why it is such a new revelation for people...
Current - 2007 Golf GTI, DSG, RCD510, K&N Panel Filter, BSH PCV revamp, Bluefin Stage 1 tune, 18" Omanyt's with RE003s.
Previous - 2003 Renault Clio Sport 172 - Flame Red. -Gone-
The main and probably only reason is to comply with ADR rules. The recommended tyre sizes are on the placard and if you go outside that you are on your own. As well there are State rules as to how larger you can go with wheel & tyre sizes. Most will keep your speedo legal but some may not. Up to you to comply
