My wife like the look of them and in theory it should be easy enough to swap over the internal electronics. I haven't actually looked at the immobiliser chip to see how hard that would be to swap over.
So, has anyone tried these things?
3 Button Key Fob Case Replacement For VW Golf Passat Jeetle Jetta Polo Bora 71.7 x 34.3 x 17.5mm-in Key Case for Car from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
3 Buttons Remote Key Case Fob for VW VOLKSWAGEN BORA Beetle Golf PASSAT S2f4 | eBay
She couldn't care less about the new style, she just liked the coloured bit (and I liked that it wasn't some stick on or silicon cover.
I didn't even think to look, but I might have to look into the videos to see exactly what is involved.
Mind you, at the moment I'm trying to pretend there isn't a problem with the lock barrel itself, my wife tells me it turned all the way around the other day ... but after a little jiggling it's working properly again and I can't feel anything different to the other car (it's not overly sloppy or rough or clicky or anything). It's working and feels just as good as it did last week :S
Best guess is that something has snapped inside and it happens to be sitting in just the right spot at the moment. I've got a quote to replace the (likely) required bits and it's more than I can really afford to spend right at the moment and while DIY would probably save me a huge chunk of that, it's also one of those parts that if you screw it up you're left with a vehicle that's undrivable. I'm hoping it hold together until I have some leave in January so I can dedicate a little time to looking at it closer.
I've just had a closer look at these and have realised the blanks I listed are for the older MKIV style keys (maybe MKV too?). Not the MKVI ones.
