Results 1 to 10 of 22
Thread: Renault stuck at 125mph for an hour
    Apr 2010
    Dec 2012
    Sutherland Shire, Sydney
    These wierd incidents are typically unexplained
    Hard to believe that the brake peddle made the car speed up
    Even if it did, you can't turn off the hydraulics, press hard and the brakes will win over power
    Then there is moving to neutral or turning the key off
    Apr 2010
    Possible that the driver didn't have his rational thinking faculties at the time but hard to believe the engineer couldn't think of that one
    I wonder if the car was stock or modified in any way, it is just a Scenic after all. For all the stuff we've done to our cars I'm surprised nothing has ever happened to a Golf, but then we have our own problems (DSG).
    Hmmm turn the car off next time perhaps. Theres a thing called a key that goes into the dashboard.
    Apr 2010
    Most car manuals are quite definite on not doing that (obviously this is an exceptional circumstance) but that could make the person wonder/worry what would happen - would they lose power steering or airbags or something
    Dec 2012
    But it is the correct action to take when running out of options and road - police have given this advice during three of these incidents
    If you got onto a straight section of motorway, it would be a safe place to perform this action
    Oct 2010
    Melbourne, VIC
    This happened (at a much lower speed) to a Ford on the Eastlink freeway down here back in 2010 and there was nothing the drive could do to stop the car
    Ford Explorer | cruise control | stuck | jammed| EastLink
    All the drive by wire controls mean that you don't have direct control of things like ignition and throttle with modern cars.
    Resident grumpy old fart
    Jun 2009
    Firstly it should be noted that the car was modified to allow him to drive becasue of his condition.
    Secondly, turning the car off will lock the steering wheel which is dangerous.
    I am surprised he made it that far without injuring anyone since he apparently had 2 seisures while driving.
    My best guess would be to grind it against the wall until it slowed enough to put it into a wall safely, otherwise put it in neutral and watch it pop the pistons ouf of the engine.
    Surely the poice could have just boxed him in and slowed him down that way enough for him to turn it off??
    Jun 2011
    Sydney NSW
    Sometimes we can be a little too smart for ourselves. With fly by wire technology, we place our lives in the hands of a programmer who requires absolutely no qualifications or experience by law. It is simply up to the scrutiny of a manufacturer where the main issue is liability and this is covered by insurance.
    It is the same in many areas where you can literally get someone straight out of high school (if you are lucky) and get them to do the work...because they are cheap.
    With the technology being common these days, you can't simply do the obvious thing like turn the ignition off because some systems will prevent the key from being turned off (or removed) once the vehicle is moving as this could mean a loss of steering or brake control. While standing on the brakes will slow the vehicle down, he was travelling at 60 mph and the speed went up to 125 mph. I wonder how many would press on the brakes that hard at 60 mph let alone 125 mph, particularly when pressing the brakes saw the car speed up.
    One thing is strange. Why would France, the home of the metric system, be reporting speeds in mph? I would have thought they would reported it in km/h.
    Dec 2012
    Quote Originally Posted by wai View Post
    Sorry but that's a gross over simplification of the design, build, test, certify process that manufacturers go through
    Manufacturers are all too aware of the legal risks they are exposed to with these systems and do put measures in place to ensure these things are well designed and tested
    Many of my flights to the US have been fully automated once reaching cruise altitude, including the landing
    If we can get automated systems to control a Boeing 747 and Airbus 380
    I think we get manually controlled fly by wire systems to work in a car
    Clearly this situation with a modified vechile is unique and may not be a car manufacturer's defect or fault
    Quote Originally Posted by team_v View Post
    2 seisures? You have to wonder if it's safe (form him and other motorists) for him to be driving at all...
    There is no car in the world that has enough power to beat it's own brakes (this was part of a court defense case in the USA)
    Let's hope the chain of responsibility is investigated/followed regarding these modifications to his car
