sorry i cant see the pics (work has photobucket blocked) but i will say this.....
things to consider when choosing relays.
all the following information should be stamped on the relay somewhere.
current rating. make sure it is up to the task you are using it for. if you are not sure of the current rating of the equipment it drives match the one you are removing. most automotive relays have contact ratings of 10A or more.
contacts. the types and number of contacts on relays can vary.. again match the one you are removing. generally you will have to anyway as a different one wont plug into the same slot.
coil voltage. make sure you get the right coil voltage.
hth
1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
