I would call BS on VWs statement as there are no marks to indicate pressure of the drip check that is applied at factory along those seams .Is it like that all the way or only certain places . I checked our 2012 model and you can see the edge of the drip check showing at the outer edges through the paint so ours could be starting to come away . On my 2005 model there is some fine rust on one side above the pass door but nowhere else , but its a different sealant method for some reason not the wrinkled finish on the later ones.
