Page 37 of 39 FirstFirst ... 273536373839 LastLast
Results 361 to 370 of 387
Thread: Nostalgia Dragster Rebuild
  1. #361
    Jun 2006
    Orange NSW
    Well... We've had a driveline failure.
    Not as bad as it sounds, but damn it made a mess. We were using a circlip to retain the jackshaft and allow it to float just a little. What i/we (probably I i guess) didn't think of was how much pressure would be inflicted on that circlip when the clutch was operated. Long story short, it's pulled the circlip out of the groove and wrecked it, pulled the jack shaft back out of the crank and that has in turn meant it had no support, so it's gone off-centre and whipped around, making a real mess of things. That shook some bolts loose, which went around the bellhousing like in a pinball machine and dinged everything up, too.
    This all started this morning when Dad adjusted the clutch linkage and got in to check the position and operation. The clutch wouldn't operate, so we set about trying to figure out why.
    Here's some pics.. And you'll notice a change in design.
    I turned down the damaged bearing surface of the shaft, then turned up a 4340 sleeve for it and heat shrunk it on with .035mm cold interference fit (The shaft is .035mm bigger than the hole). Then turned down the sleeve to the appropriate bearing diameter, leaving a 4mm shoulder in place of the previous 3mm circlip. That's not all we had to do, but that explains the pictures i've got.
    It will now have a greater surface area, more support and we aren't relying on a damn circlip.. So i'm much happier.
  2. #362
    Jun 2007
    Eastern Suburbs Melbourne
    good work mr metal man!
    i like volkswagens
  3. #363
    sydney
    very tidy repair bro
    it still amazes me how much trust is place on circlips split pins and so on
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
  4. #364
    Jun 2006
    Orange NSW
    Quote Originally Posted by alex g View Post
    Cheers dude.
    I don't trust circlips or split pins for a lot of things. I'd much rather a definite solid locking mechanism. But i had assumed there would be bugger all force on it, so i wasn't concerned. Really should have thought that through a bit more, but ah well, you live and learn.
    On the up side we breezed in getting it all back together yesterday and it's all sweet as. We also trialled a method of boiling the Nitro out of the old oil too, which seems to work quite well..
  5. #365
    May 2010
    Nice work!
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
  6. #366
    Jun 2006
    Orange NSW
    Well, we did the first push starts in Australia in over 30 years today.. All successful. Here's a teaser..
  7. #367
    May 2010
    Love it.. thanks for sharing!
    Am surprised at how well she turns.
  8. #368
    Jun 2006
    Orange NSW
    Quote Originally Posted by Speed View Post
    30 degrees of Caster.. It looks better than it is! haha.
  9. #369
    Jun 2006
    Orange NSW
    I got two pictures today.. Just two. But ah well. Video is better. it has SOUND!
    It's amazing what you can do with occie straps! haha.
  10. #370
    Dec 2007
    Brisbane, Southside...
    Wicked video. Love the sound.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
