Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Moon plates / cv washers what's the story.
    Perth. WA
    Quote Originally Posted by Jace View Post
    Maybe to help prevent the head of each bolt shearing off? One strengthening the other?
    Dunno, i understand what i mean.
    I would say most likely correct, Socket head cap screws ( torx etc) and other higher strength fasteners are usually made with a rolled radius under the head, the plate or washers allow clearance for the radius as to not bind on the item being clamped together. There exists a greater chance of fastener failure if the radii under the head is interfereing with the bore of whatever is being held together.
    Check the head bolts on your VW head, hardened washer to give clearance , spread the load and minimise galling of the alloy head.
    HTH.
    Just had a quick read of Carroll Smith's nuts, bolts ... - Google Books
    And he says that its purely spreading the bearing load of the fastener. You should get a copy and have a read Al, good book along with the rest of his literature 'thumbup icon'
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    sydney
    I would belief that that radius would actually aid the tension as it's an increase in surface area ala countersunk hardware. Having said that that still doesn't explain the paired format.
    Maybe
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    sydney
    Finally a definitive answer, I just saw the solid state and mass of the flange not to benefit from such load spreading, and come to think of it the torque numbers aren't that high.
    Yer will have to check that one out.
    Boronia VIC
    The CV boot flange it's bolting to is pretty thin. if a bolt or washer rotated against it it would likely tear or buckle the metal.
    Might would be a way to stop the bolts ripping up the flange, preventing the grease having any way to get out.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Aug 2009
    They just look ****ing awesome.
    Suffolk UK
    This;
    Quote Originally Posted by OEM G60 View Post
    Joined to stop the washer turning as you tighten the nut/bolt??
    and this;
    What do we win?
    sydney
    Yer Pete gets the win, was thinking of the later driveshafts with the different style cv boots, and forgot that the early models mount on the outside of the flange.
    Happy now.
