If you're ever on game show with, say, a GTI as a prize, you may want to know about this . . .
Suppose you're on a game show, and you're given the choice of three doors: Behind one door is a GTI; behind the others, goats. You pick a door, say No. 1, and the host, who knows what's behind the doors, opens another door, say No. 3, which has a goat. He then says to you, "Do you want to switch from door No. 1 to door No. 2?" Is it to your advantage to switch your choice?
As the player cannot be certain which of the two remaining unopened doors is the winning door, most people assume that each of these doors has an equal probability and conclude that switching does not matter.
In fact, all things being equal, the player should switch—doing so doubles the probability of winning the car, from 1/3 to 2/3.
Worth knowing if you ever find yourself in the enviable position of being in the running to win a car!
GTI MKVI Candy White | 5 door | DSG | ACC | 18" Detroits | Leather | Electric Seat | Sunroof | RNS510 | Dynaudio | Park Assist | RVC | MDI
Apparently not:
http://en.wikipedia.org/wiki/Monty_Hall_problem
wrong.
combinations are:
(1) (2) (3)
goat goat car
goat car goat
car goat goat
you pick door 1, chances of car, 1 in 3
the fact that the host shows you a goat doesnt change that.
you double your chance of a car by swapping.
I proved this to my sister using cards. She still thinks it's magic.
2009 118 TSI
1980 Bedford van
2015 Hyundai i30 SR
In reality though, you still only have a 50:50 chance of having the car behind the door you chose or the door you didn't choose becasue it has to be behind one of them as the other door revealed a goat.
However, schroedingers cat apply's because you never know if you changing doors will change what was behind the doors.
Not so, I have to say:
From the outset you have a one in three chance of selecting the door with the car first off.
This means that there is a 67% chance that the car is behind one of the two doors you did not choose and a 33% chance it is behind the one you first chose.
These percentages do no vary after the door with the goat behind it is opened.
We already knew there was a goat behind one of the two doors you did not select; now we just happen to know behind which of the two other doors the goat was hidden.
As the two doors we did not choose initially still have a combined 67% chance of having the car behind them, with the knowledge that the GTI is not behind the door that has been opened, if you swap, your chances of the car being behind your second choice are 67%, not 33% or 50%.
So if you swap, on average, you will win twice as often.
the problem here is that each time time one door is eliminated, you start with a fresh set of variables and probabilities.
so at first choice, your chance was 1 in 3, but once the first door is out of the equation, then its 50:50 for both doors, whether you change or not.
Like tossing a coin, you have a 50:50 chance of getting a tails, but just becuase the first toss revealed a head, doesnt mean the next toss will reveal a tail.
the next toss is still 50:50 for a tail vs a head.
Probabilities and 50:50 outcomes are only realised over a very large sample.
also, and more importantly accept that Murphys Law is the more powerful law stating that which ever door you choose will have a goat behind it
2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
Out of respect for the preferences of others, I make no comment as to whether the above comment is correct or not but refer the author to the discussion at:
PS - I do not wish to imply that I have any issue with the comment about "Murphy's Law" except to say that, in my opinion, Murphy was an optimist!
