team v, you really shouldn't be allowing work to get in the way of priorities - go chat to the boss!
This is as pointless as the MT vs DSG thread.
You have 3 doors, 33% chance each.
Remove 1 door, only 2 doors remain.
Removing 1 door means that you can no longer use the 1/3 chance breakdown you have used previously and as such must revert back to 1/2 chance unless you actually count choosing the goat as an option.
since you are not going to choose the goat, 1 of the remaining 2 doors has the GTI, the other doesn't so you have a 50% chance no matter which door you choose.
Having said that, you then have to apply Murphy's law stating if you have a 50% chance, 90% of the time you will choose wrong.
And schroedinger's cat also screws with the results.
Bloody Garath beat me to it.
Stupid work getting in the way of my forum viewing time.
2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
As stated plenty of times already in this topic, its complete BS.
If you take into account that your original choices include a 1/3 chance of winning, and then the host improves the odds by taking away one of the choices, then yes, given the original odds, you now have a 2/3 chance of winning WITH EITHER DOOR.
But as stated previously, the variables have changed, and so must the odds - so you now have a 1/2 chance of winning.
People try to use mathematics to solve the equation, and just end up complicating the problem - when all they really need is simple arithmetic:
1 + 1 + 1 = 3
3 - 1 = 2
To demonstrate the flawed mechanic, the whole idea of 'switching your door' giving you a 2/3 chance to win, relies on the first mechanic - that you did not choose the prize in the first place (which is an original 1/3 chance). If you happened to win that 1/3 chance, then 'switching your door' gives you a 0/3 (original) and 0/2 (progressive) chance to win.
Should you happen to choose a goat first (2/3 chance), the 'switch mechanic' gives you a 2/3 (original) and 1/2 (progressive) chance to win
HOWEVER
If you take into account that the modified fraction chance values can not exist until the original fraction chance value has been solved (ie: door chosen) - then it becomes obvious that in order to correctly calculate the odds, the variables must be processed first.
Which again is simple maths:
1 + 1 + 1 = 3
3 - 1 = 2
But....but....what if there wasn't a GTI behind the "3rd" door?
In fact...what if they had 3 goats behind the 3 doors.....and only wheeled the GTI up to show you what you missed when you made 2 dud choices....
What's the odds with that?
http://www.youtube.com/watch?v=mhlc7peGlGg
This is the best explanation. Annoying voice though.
Sunroof // ICT Tint // Seats // Steering wheel
