Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Modern technology friend or foe .
  1. #21
    May 2006
    Adelaide South Australia
    Quote Originally Posted by theresanothersteve View Post
    I wish they would get back to the driving experience,
    VW & others don't help by deleting most models with manual trans. My wife agrees with me that most autos turn good cars into white goods. I know that there is a place for an auto. but most of the buying public don't care & say "why would you buy a manual".
    I have a couple of friends who have bought new cars recently & didn't even have a test drive.
    Numerous Mk1 Golf diesels
  2. #22
    Mar 2014
    Bundoora, Victoria
    Compared to my MK3 Golf, you can't feel the speed in any new car. In the Golf if I'm doing 60km/h it's fun and I can feel it, it's like a go-kart. It's small and personal. In the Focus I could probably fall asleep doing 60 the revs are so low and everything is quiet.
    A part of me doesn't want to sell it, but then maybe it's time to move on and I'm being nostalgic for the sake of nostalgia.
    Past - '95 VW Golf MK3 VR6
  3. #23
    Sep 2015
    Quote Originally Posted by Bug_racer View Post
    I pull the manifold off to get to the back of the valves and intake ports to clean them .
    Does it make that much of a difference , Id say so given I have the fastest unopened stock turbo Golf R in the world and the fastest (currently) Golf R in Australia over 1000m which is faster than the next 3 Golf Rs which are all big turbo cars
    I doffs me cap to you, and give you kudos for holding records, but it's hardly the point.
    For the average driver pulling heads off for decoke, servicing every 3,000 miles, replacing spark plugs every 6,000 miles and so on are a thing of the past.
    Technology has led to more reliable vehicles, but when they break down the average punter has to send them to technicians.
  4. #24
    Apr 2006
    VW Race HQ - Sydney
    For me Carbon cleans are a regular item I do , not just on my car but customers .
    if this carbon build up would happen to cars with carbys and points there is no way you could ever get it to run right . Modern ECUs have the ability to control injection and ignition to each cylinder as well as having inputs like the lambda probe and knock sensors . Due to the processing power of the ECU issues that the car might have can easily be masked . Unplug a MAF or coolant sensor and see if that changes how a modern car runs , do the same with a mk2 or early mk3 golf . I dont believe modern engines are as completely reliable as what they are made out to be , they are just a lot better at masking issues than earlier cars . Almost like they were built to last the warranty period and then the heavy maintenance would start . But , in saying that if you are prepared to spend more money on maintaining them then they can last quite a while with the benefit of being safer , more fuel efficient and more powerful . Its just hard for some people to justify $1k for a carbon clean when the car still runs ok .
    Bug_racer supports the rebellion of the euro revolution
  5. #25
    As per my last post - using water only costs you 30 min of your time and gives the same result.
  6. #26
    Apr 2006
    VW Race HQ - Sydney
    I doubt it , also its not going to help with carbon build up on injector tips
  7. #27
    Mt Cotton
    I forgot to add these two to my original post , DMF is the most stupid part for a manual T5 van meant to carry up to one ton of weight because small engine capacities do not have the grunt to overcome the weight which leads to the DMF disintegrating prematurely . My second one is the ridiculous "Sealed for Life " on the T5 Tiptronic autos , VW were blatantly oblivious to our climate and the effect on the fluids viscosity during our long hot summers and every day driving conditions . Strange thing was in 2010 VW decided to release the DSG in the Transporter vans and wonder of wonders they then said that autos SHOULD be serviced at 60000 kay intervals plus the fitted the filter on the OUTSIDE . My memories of my auto in my 68 VF Valiant V8 was that you could drive to a trannie shop they would remove the sump pan tighten the bands and replace the fluid and you would not get the problems that seem to be plaguing these modern technological nightmares .
