Yep, on a league of its own!
Yeah I'm sure a HSV would be quicker/larger, but a new AMG with that power and specs for under 100k?! Next car for sure!
very nice hoffie what delivery times are they quoting?
B6 Passat Wagon No KESSY
There's been a LOT of changes in piezo injectors, as with all things, and the problems with the early ones was all down to sealing the piezeo stack from oil, which over time builds up metal particles and thus becomes conductive. This also assumes the injector is bathed in oil, which is mainly the case in the old mechanical, cam driven PD injection systems. Sure it still happens, but common rail in the diesels, and most petrol cars can work around that pitfall and keep the piezo stack out of the oil. A piezo injector in air should outlast the car.
I'd have one of these new babies in a heartbeat if I could afford it!!!
Agree - not the prettiest proportions around. I looked at one in the flesh, and was not impressed with the interior ergonomics - nothing tops VAG for that. The LCD display screen looks like a complete after thought. Stuck on a little arm in the middle of dash. Why not have it pop up out of the dash?
I'm splitting hairs of course. If I had the cash I'd sure be keen to short list it.
MY18 GOLF 110TSI I HIGHLINE I Indium I Panoramic Sunroof I DAP I IP
MY18 TIGUAN 162TSI I R-LINE I Ruby I DAP I IP
Merc are using piezo injectors in a lot of there cars. Most notable in there v6 diesel engines which have been going strong for a while now.
The army versions have been kicking around Aus in trials and now in units for nearly 2 years and not one has failed due to manfacturing fault.
Yeah, there's a lot of misunderstanding about the piezo electric triggering of the injectors - the basic principle is very sound but the implementation in the unit injectors for the high performance VAG PD diesels by Siemens/Bosch was flawed due to the heated oil that surrounded the wiring in these engines.
The newer common rail engine injectors (including VAG ones) almost all use piezo electric triggering to allow the much more precise control than solenoid triggering which is what makes the common rail engines so much more refined (since many more injections/cycle are possible) and in these engines, the wiring isn't bathed in oil.
Resident grumpy old fart
shut up.
when the time is right, we can finally chirp tyres again.
A45 = "im so comfy but why did that little car murder me?". folks, keep in mind that our roads are pretty intensive... unless you're ghey (big power, no suspension travel).
