Results 1 to 7 of 7
Thread: Mechanical Advice - Non Veedub related content
    Sep 2012
    Wonga Park, VIC
    Hey Fellas,
    I need some mechanical advice for my work ute (2010 isuzu dmax).
    Recently on cold starts first thing in the day, when I press the accelerator I get nothing, nothing, nothing, then the revs kick in finally but it's very much low in power, as if hand brake is on. Then once it starts moving, 4-5 seconds, it all runs smoothly.
    Once warm this doesn't happen, and when starting again during the day it's also fine, unless it's been still for like 4 or so hours.
    What would be causing this? Any idea's?
    May 2012
    How cold are we talking? Diesel gelled?
    p.s. This is a wild guess, wait for a real mechanic to pipe in!
    Sep 2012
    Wonga Park, VIC
    Not cold enough for that, like overnight melbourne temperatures, so like 10 degree-ish.
    Thanks anyways maelgwn
    Jun 2011
    Sydney NSW
    Sounds like a sensor that is not working properly when cold.
    Dec 2009
    Kew, VIC
    Could be several things — turbo not kicking in until something warms up (sticking valve or vanes, carbon buildup up etc) — dirty injectors or filter — pump slow raising fuel pressure — a sensor slow to react when cold (MAF?) — none of the above...
    I wouldn't hang about in getting it diagnosed — modern diesels are not the simple things we used to run last century, and what looks like a minor fault can become expensive if not followed up promptly.
    Dec 2008
    Sydney/Canberra
    Have you had it scanned?
    What are the fault codes?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Aug 2012
    Churchill
    Could be sticky throttle body, solenoid faulty. Would be a drive by wire
    2011 B7 Passat TDI highline wagon. I tinted the windows Mechanical Advice - Non Veedub related contentMechanical Advice - Non Veedub related content
    2011 B7 Passat Highline Wagon TDI. I Tinted the Windows
