How cold are we talking? Diesel gelled?
p.s. This is a wild guess, wait for a real mechanic to pipe in!
Hey Fellas,
I need some mechanical advice for my work ute (2010 isuzu dmax).
Recently on cold starts first thing in the day, when I press the accelerator I get nothing, nothing, nothing, then the revs kick in finally but it's very much low in power, as if hand brake is on. Then once it starts moving, 4-5 seconds, it all runs smoothly.
Once warm this doesn't happen, and when starting again during the day it's also fine, unless it's been still for like 4 or so hours.
What would be causing this? Any idea's?
Not cold enough for that, like overnight melbourne temperatures, so like 10 degree-ish.
Thanks anyways maelgwn![]()
Could be several things — turbo not kicking in until something warms up (sticking valve or vanes, carbon buildup up etc) — dirty injectors or filter — pump slow raising fuel pressure — a sensor slow to react when cold (MAF?) — none of the above...
I wouldn't hang about in getting it diagnosed — modern diesels are not the simple things we used to run last century, and what looks like a minor fault can become expensive if not followed up promptly.
Have you had it scanned?
What are the fault codes?
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Could be sticky throttle body, solenoid faulty. Would be a drive by wire
2011 B7 Passat TDI highline wagon. I tinted the windows![]()
2011 B7 Passat Highline Wagon TDI. I Tinted the Windows
