Results 1 to 8 of 8
Thread: Master cylinder plumbing
    Apr 2009
    Just a quick question, when changing over from the original master cylinder (the 5 port ones) to the ones from the seat cordoba (the 4 port ones see pic below) does it matter what way I connect the brake lines.
    For example, do the rear brake lines need to be connected to the back holes and the front lines on the front. Or can I just connect them how ever I feel like it?
    This is the seat cordoba master cylinder with two holes (image there being 4 )
    -'75 Passat TS
    -'75 Passat TS (Project)
    No....its not a Piss-sat its a Pass-sat!!
    Boronia VIC
    Should be diagonally split.
    Front left and rear right off the same port.
    Front right and rear left off the other.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Apr 2009
    hmmm I think I understand.
    Just to elaborate, so for the front calipers, their brake lines will connect to the Front Right and Rear Left.
    And for the rear calipers, their brake lines will connect to the Front Left and Rear Right.
    Is that correct?
    -'75 Passat TS
    Boronia VIC
    7? MK1 Caddy
    12 Amarok
    Apr 2009
    Yea thats a good diagram but my MC has 4 (four) connection holes for me to connect the brake lines too. If I go with that diagram that means I have to seal off 2 (two) of the 4 (four) connection holes leaving me with 2 (two) connection holes therefore allowing me to go with that diagram.
    Is that what you are suggesting??
    -'75 Passat TS
    Boronia VIC
    7? MK1 Caddy
    12 Amarok
    Apr 2009
    haha I love ya Pete, Thanks. I see your more into calligraphy than words tonight.
    p.s. Im going to take that image as advice and plumb it that way. Hope it was not a joke or anything.
    -'75 Passat TS
    Boronia VIC
    That'll do it. I just couldn't be bothered typing. Both pictures are hydraulically the same, it's just the t peice is 'internal' on a 4 port cylinder.
    7? MK1 Caddy
    12 Amarok
