I'm on the hunt for a wrecker with a 118TSI (I'm sure there should be lots of them!) to scavenge the PCV breather pipes to build myself an oil catch can. The idea is to make up the required parts without having to pull mine apart or sacrifice the ability to go back (should I ever need or want to). It also means I still have a driving car if I screw something up
Part number is 03C 103 474 AB is that helps.
To that end it can be busted up since I'm going to have to cut it up anyway, so a broken cheap one would be perfect and much better than the many hundreds of dollars a new one costs.
