![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
BluChris
Hey, I did suggest a Yaris first, but the brief seems to be straying a long way from the OP's original question
![Smile](https://www.vwwatercooled.com.au/forums/images/smilies/icon_smile.gif)
Any of the European cars suggested here at less than 10k are likely to be a gamble.
I still think the first idea of a cheap Japanese runabout plus a fun project car makes more sense than buying 2 cars that could both turn into projects. That said if you're going to make the daily a project as well, might as well make it something with an interesting starting base rather than a cooking model you have to put a lot of work into just to get it beyond boring
A $10k 9N3 TDi wouldn't be a gamble. And note that the OP has specified
but will be driven to the snow (I'll get chains)
which would be a dreary experience in a lot of the small Japanese cars mentioned.
A ~2005 Ford Focus wouldn't be bad as it had the best chassis in its class (better than the MkVI Golf that we replaced ours with) and the equivalent Mazda 3 would be reasonable, too, since it's pretty much the same chassis
eg http://www.carsguide.com.au/cars-for-sale/D_1887836/
This Nissan Pulsar would be a decent option, as well http://www.kingstoncars.com.au/Autom...3/details.aspx
Resident grumpy old fart
