Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Thread: iRacing releases the VW Jetta TDI Cup
  1. #41
    Canberra
    Quote Originally Posted by static1800 View Post
    Just signed up for Iracing, got the Lotus 79 as a bonus
    might be a while until it lets me drive it though
    You will be able to drive it on the Test track, but not competing.
    Also mate, if you did the $60/6 month deal, you should also have got a $25 bonus, I think. I'm going to spend $15 of mine on the VW Jetta. Even as a Rookie you can race the Jetta if you get your safety rating up to 4.0 (I think). That's my short term plan, anyway.
    It will be good to get out of the Pontiac Solstice (sluggish) and into the Dub.
  2. #42
    Apr 2009
    Melbourne, VIC
    The sequential shifter on my Logitec Momo Racing wheel (I couldn't justify the G25 - esp. with less wheel bbuttons) for brake bias which is GREAT! I can adjust it to be perfect for different corners. If they remove a sequential shifter functionality I might have to consider keeping my current setup even longer!
  3. #43
    Apr 2009
    Melbourne, VIC
    I should note I only use the paddles to shift... Not 100% accurate for all cars I race, but the quickest and easiest way to be fast.
  4. #44
    Oct 2005
    Nowra, NSW
    Started playing Iracing last night, for some reason my G25 is having a massive issue with force feedback. It was shaking violently when ever you turned the wheel and wouldn't stop! so had to turn it off.
    Had a go at the Solstices, was quite a bit off the pace though when i tried a race then totaled my car
  5. #45
    Canberra
    What are your Profiler settings and what driver version are you running? It might pay to uninstall them and grab the latest ones from Logitech website.
    Also, check you have the wheel rotation set in the Profiler for 900 degrees, iRacing then automatically sets the correct steering ratio for the chosen car.
  6. #46
    Canberra
